EXTREME OVERHEATING
davidhozic
EXTREME OVERHEATING
Hello,
Can someone give me their info onvhow their temps are?
My phone is sitting from 32°C when not using it to a whopping 43°C when doing basic things like watching yt or web browsing. Either my phone has a problem or it's a software issue with temp limits..
8 REPLIES 8
Lord_viridis
How are you measuring this temperature and where on phone?
mipa_xa
@davidhozicwrote:
Hello,
I'm not having any of the problem you reported even after 20 minutes of continuos benchmarks. The phone does not get crazy hot, just acceptably hot and today is a hot day here so I'm not doing a test in a cold room.
If you have already removed any bloat that can cause overheating (bad apps, Facebook and stuff like this) and any software modification that can lead to different results from stock (Xposed), your device is clearly faulty.
profile.country.US.title
Qatrium
@davidhozic
In another thread, you said that you have your bootloader unlocked. Does this mean you also have a custom ROM or at least altered your software somehow?
davidhozic
No i just have magisk and i even underclocked my cpu
davidhozic
I use kernel auditor and accu battery to messure.
The temps that rise first are from the cpu and then the battery, i dialed the clocks down a bit to help with the heat but didn't do much
davidhozic
Im taking my phone to the repair service to fix the lcd's backlight bleed and maybe
they fix the temps too.
RE1281
Heres something. Wen I have hotspot on, nfc on, bluetooth on. Phone goes up to 55c. Becomes slugish. Worst phone I ever purchased
davidhozic
I mean maybe its because the camera 23 MP but still i don't think the preview is 23 MP
