Call not disconnecting
pthumati
Hi guys,
My phone not disconnecting the call sometimes and if i restart then only i am getting chance to make new calls. IF any once has solution please share with me.
Thanks inadvance,
5 REPLIES 5
Brobddy
did you press RED button to end a call?  does it changed status while you pressed?
profile.country.NL.title
Strampke
As an extra test you can try this:
Goto Setting -> Accessibility -> Power Button ends Call
pthumati
Hi , I tried multiple times but still call not disconnecting.
Thanks for the suggestion.
pthumati
When I enabled the "Power Button ends Call"  not ending the call and also I could not restart the phone. Thank you for the suggestion guys.
Brobddy
make factory reset and test for a calls
do not install any apps before test, probably some apps block a call
