Il mio Bluetooth si blocca all'accensione... Mi dice applicazione di condivisione bluetooth non disponibile... Ho provato di tutto ma niente
My Bluetooth stops responding ... It tells me bluetooth sharing application not available ... I tried everything but nothing
GT
Hi @Marco2710,
Please use English in your posts, as this is the designated language of the forum and will ensure that you get the maximum number of replies...
For everyone else, the post was:
When are you seeing this error message, @Marco2710? What are you trying to use the bluetooth with (e.g. computer, vehicle, headphones, etc...)?
Try putting your smartphone into Safe Mode and see if you still have the same problem...
Let us know how you go!
The problem appears immediately, as I click on the Bluetooth icon from the quick menu, a window that says Bluetooth sharing app does not respond ... I tried to erase the data, end the application, restart the device but nothing. ..experia xa1 dual sim, Android 7.0 ..... I was talking about connecting Bluetooth headphones but even before I did it I noticed the problem
Yes ... I have the same problem, as from photo !!!
I can't see the photo at the time of writing, because these forums require a moderator to approve it first and it usually takes them a fair bit of time to "approve" photos...
Something to try meanwhile?
Try a software repair with Xperia Companion and see if the problem still persits afterwards...
Im out home, tomorrow i'll try... Thanks
