My battery is on 100% and yet the phone tells me that I have 5hrs of battery left. Is this normal? I am using an Xa2 Ultra
Hi @Shadreck, welcome to our community!
Do you see this information in Settings > Battery and it says "5 hour remaining" here? This is only an estimate and is based on how much you have used the device. If you for example, put the device on a table and you go to bed it will say that you have a lot of hours remaining when you wake up, as the device has not been in use, since you have been sleeping.
I hope that helps and I'm sorry if I misunderstood your question.
