battery problems
Omar78
battery problems
Pongo a cargar el celular y solo llega al 67% de hay no pasa no llega al 100% si el tiempo estimado de carga completa era de aproximadamente 2 a 3 horas máximo y ahora se tarda más de 4 y no completa que puedo hacer gracias
I charge the cell phone and it only reaches 67% of there is no pass does not reach 100% if the estimated time of full charge was approximately 2 to 3 hours maximum and now it takes more than 4 and it does not complete that I can do thanks
@Omar78
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you using Sony's wall charger and cable? have you tested a different charger? how about safe mode?
