My phone have the following problem after upgrade to Android 8.0.0:
1. the phone become very warm than normal when using and charging,
2. the battery consumption is high, 3 hours to use 80% of the charge after full charge, and
3. the charging is also very slow.
Please advice whether the ROM Build No. 48.1.A.2.21 is suitable for Xperia XA1 ultra.
Thank you.
Hello @Lingus
And welcome to the forum
So sorry to know that
Can you please tell me if you update your device today or this week? I'm saying this because after a major android update, the phone takes some time to settle everything in the background!
Some processes initiated by the update will continue running in the background for some time, for example:
The processes running in the background are using the processor a lot, causing the device to be temporarily perceived as slow for a day or two. This behaviour is normal during indexing and app updates.
Please, let me know your feedback!
Hello,
I have the same problem after upgrade 05/06/18 Xperia Xa1-ultra (48.1.A.2.21)
How can I downgrade my phone to previous firmware version?
Hi @AlexBBB
Since you have updated two days ago, i recomend you to wait till tomorrow, since when you have performed an Android system update, it may take up to two days for the device software to stabilise.
It´s not possible, by any official way, to downgrade your device!
If the problem persists, i recomend you to restart the device. If that doesn´t help, you can try or a factory data reset or a software reapair, using Xperia Companion!
Please, be aware that those two procedures will erase all the data you have expect the one present on an sd-card. You can make a backup to a computer using the Xperia Companion.
You can also format your sd-card, since it will remove all files and folders including any leftover data and corrupted file.
To perform a factory data reset
Performing a software repair
Formatting the memory card
Plese, let me know if that helps!
