60% in 30 min by 2.7 mA charger with 2.0 pump express... But it take 60 min for 50% charging ..only 2300 mAh battery. Bad performance by mobile
I think you might got the wrong device category, you may discuss about xperia xa1, but other members would see that the chosen category doesen't match the one you're talking about.
You should change it to xperia XA1 if you have mentioned 2300 Mah battery, because Xperia XA1 Plus has 3400mah. Hope i didn't made you mad.
