Xperia X double tap to wake up issue
nice_new007
I am Xperia X owner and current build version is 34.3.A.0.217. I have issue regarding double tap to wake up and it is present since many updates, many updates received but this issue still not fixed. It requires many attempts to wake up. It is not working like double tap to sleep.
Tags (2)
10 REPLIES 10
profile.country.PL.title
najodleglejszy
from what I remember, it should work better if you tap close to the center of the screen. also it's possible that a screen protector is making it more difficult to register the taps.
nice_new007
Yes, there is screen protector glass but It is working fine in double tap to sleep.
Tags (1)
najodleglejszy
yeah, but there might be a difference in the way the phone handles taps when the display is on and off. that said, the best I can advise for now is to, as I said, either try tapping near the center region of the screen when trying to wake it, or see if anything improves without the screen protector.
nice_new007
I tried in all region of the screen but not working accurately.
Icegabri
Same issue
severmaya
Same here, double tap to wake issue. And nothing fixed
Raffocel
Translation via Google Translate:
Best regard
The same thing happened to me with an Xperia x after 7.1.1 update .. it's as if the sensitivity was not the most appropriate ... I had to press hard to wake up ... until I decided to restore it with the Xperia companion ..and after that it was solved ... now the double touch is immediate
I leave the link of Xperia companion:https://support.sonymobile.com/co/xperia-companion/
Cordial saludo
También me pasó lo mismo con un Xperia x después de actualización 7.1.1.. es como si la sensibilidad no fuera lo más adecuada...me tocaba presionar fuerte para despertar...hasta que decidí restaurarlo con el Xperia companion ..y luego de ello se soluciono ...ahora el doble toque es inmediato
Te dejo el link de Xperia companion:https://support.sonymobile.com/co/xperia-companion/
nice_new007
Still facing same issue. I updated Oreo using PC companion.
profile.country.NL.title
Strampke
Hey @nice.new007
On my device DTTW is flawless.
Maybe you should goto settings-> tap magnifying glass->type support and do some screen tests (!:smileysmileywink:)
Just to find out if it is the screen.
Other test maybe to into safe mode.
