Xperia X charging stuck at 3%
angeline03
I've been trying to charge my phone for the past few hours! Slightly_frowning_Face It was at 2% after charging from 0%, there was the thunder logo at the battery; after turning on my phone , it was stuck at 3% with the exclamation mark at the battery. I tried holding the lock & volume up  button to reset but don't work, my phone restarted and still at 3% exclamation mark. Now I need to plugin charger to use my phone cause my phone will die once I unplug.
Appreciate to get assistance to resolve this issue asap, I need my phone.
Thank youPeculiar statistics as I spend at least 3-4hours on my phone daily, and today is May 12th.Peculiar statistics as I spend at least 3-4hours on my phone daily, and today is May 12th.
2 REPLIES 2
schetz
Have you tried :
- different cable
- different charger
- to charge will phone is off
Repair with Companion is out of the question now I think, as it requires certain battery level.
angeline03
Thanks for the suggestion! I got it checked. I was told the terminal was lose hence it couldn't charge. It's fixed now Slightly_smiling_Face
