Xperia X battery life behaves strange
Andilla
I have a problem with my Xperia X battery: from 100%, it doesn't last longer than 4 hours.
This low life is only one thing, but it is also a mystery to know WHY, the numbers just don't add up.
An example: I checked the battery usage of all applications and it was only 39% for all the Apps, but the battery was already empty, 2%.
I only took maybe 60 photos, then viewed them, edited some and deleted a few. No music, no calls or anything else.
How do I find out where has the other 60% of battery life gone?
Monitoring the battery usage, this is what I see:
From 13%, it dropped to 2% within 30 minutes.
At 13%, the remaining time was 2h 40min, later at 2%, it's only 50min!
Which means that 1h 50min worth of battery life was used in 30min only.
What gives?
Tags (2)
profile.country.NL.title
Strampke
Hey @Andilla
Diving up here too?
With such strange behaviour you should really consider software repair.
See you on the other side :smileysmileywink:
