hi all guys
I am having the problem of drain battery after updating to 7.1.1
I got a log of this system and showed it constantly:
E/QMI_FW ( 1806): xport_reg Failed for service_id=0x35 version=0x1001 on 14
The problem is the pm-service file.
Thanks for help.
7.1.1?
You should be on 8.0.0 I presume.
Can you check is in settings ->system->about phone
When your phone is acting weird you can start by checking if it is doing so also in Safe Mode
Safe Mode -> push on/off button and then long tap on restart.
You will be given the option to restart in Safe Mode
If that doesn't give you a solution you might consider to do a software repair using Xperia Companion, but only after you made a backup of course.
