wifi signal
King13
wifi signal
Problem da gubljenjem WiFi signals. U prostoriji gdje se nalazi ruter, tel ima signal dim be usmjeren prema njemu. Šta he problem
Problem by losing WiFi signals. In the room where the router is located, the phone has a smoke signal directed towards it. What a problem
gt
Tags (1)
2 REPLIES 2
Mohid1
Wifi signal issue
profile.country.NL.title
Strampke
Both problems I don't really understand what's the matter.
Anyway.
A standard test method is to see if the unwanted behaviour persists in safe mode.
If it is better in safe mode then an app is interfering.
Other thing to try is: settings-tap magnifying glass-type 'reset'- find reset network settings and reset.
Then try again
Tell us please if there is a thing that helped you.
