Hello,
is somehow possible set on wifi 'preferred site' ?
Hi @ZAJDAN,
I'm not quite sure that I understand your question.
Could you please give some additional information on what you mean with "Preferred site"?
Thanks in advance!
I have two ESSID on same place, the signal is same also. Each the ESSID has own subnet and own gateway....
I have access on both the sites, but one from them I would like to use as preferred/primar. Now my mobile device select the site randomly.
Hi again!
Now I understand what you want to do, thanks for the information!
I'm afraid that there is no setting for this in the phone, however if you can move around freely and be in range of the network you want to use as the preferred one, you can go to Settings > Wi-Fi > tap on the network you don't want to use and tap on "Forget".
Now the phone will automatically connect to the network that you want it to be connected to.
I do understand that this is probably not what you are looking for, but unfortunately there is no setting in the phone that you can use, I can however see how this can be a useful setting to have so I will make sure to forward this internally as user feedback!
I hope that answers your question!
