Meu celular está com. Problema no carregamento está demorando quase um dia todo para carregar
My cell phone is on. Loading problem is taking almost an entire day to load
GT
Forum rules ask us to post in English - use Google translate if needed.
Do you mean it's taking a day to boot up?
If so, dues this happen in safe mode?
If yes, then it's a back up (if possible), reset and repair via Xperia Companion.
Failing that - off to a Sony Service centre.
Seems charging related.
Try different charger, cable and combos of the two, cleaning usb port, checking up usb port, software repair.
This is the order in which I would approach the problem at least.
