"Battery care" if I charge only once every two days
Cirelli94
Is it possible to enable "battery care" function if you charge your smartphone only every two days?
Or does it work if you charge it daily?
And another question.. What is the timeframe in which I have to charge my phone in recharge so that "battery care" works?
2 REPLIES 2
If1
your phone should "learn" your habits.
Please check
https://support.sonymobile.com/global-en/xperiaxcompact/userguide/battery-and-power-management/
"Battery Care will not control the charging rate until it detects a regular charging cycle of at least 4 hours over a period of several days."
JavierGS1
Yes it works, since I have it (2016) I have always loaded it every two days, and with Marshmallow and Nougat it almost never detected it, but since the update to Oreo every time I charge it, battery care is activated.
