Hello guys, some help please. I'm seriously getting very bad battery drainage and according to battery stats, phone idle is consuming around 40% of the battery. This has been happening since the Nougat update and now, the Oreo update. Are you guys aware of this? Can it be fixed? Thanks.
Battery drain has a cause. You might check to find out where is comes from.
Maybe this post can give you some guidance.
