My model is Xperia X (F5122), but when I repaired my phone with Xperia Companion, an error occurred.
like this:
An error occurred while repairing your device.
Please try again. If the problem persists, contact Sony Support.
UEGetPhoneInfoMissingInfo
F5121 3580 1304-8560 R4E 34.4.A.2.19
1.9.2.0 / Windows 10 64 bit / Win32 / CN
This is LOG:
029374ms: UEsession: runSendSmartPing completed successfully, waiting for response... 029994ms: UEsession: Response to smart ping, UE at http://192.168.0.104:58088/ and local listener at http://192.168.0.104:57688/ 029994ms: UEsession: runSendLogin no active device type found, proceeding to fallback 029994ms: UEsession: runSendLogin device is commercial 029994ms: UEsession: runSendLogin commercial login set 029994ms: AppSettings: App settings requested 029994ms: AppSettings: Loading app settings from disk 029994ms: UEsession: runSendLogin without proxy per manual setting 029994ms: UEsession: No proxies (left), logging in to UE with no proxy 029994ms: UEsession: runSendLogin will login anonymously 030269ms: UEsession: runSendLogin completed successfully 037370ms: UEsession: UE responded to login 037370ms: UEsession: Logged in to UE! 037370ms: UIState: UI devicerepair updated to repairDeviceInstructions 053213ms: UEsession: Device connection detected! 053272ms: UEsession: runSendGetAllConnections completed successfully 053333ms: UEsession: UE responded to getAllConnections 053333ms: UEsession: Device connection detected 053333ms: UEsession: getAllConnectionsResult returned device connection successfully! 053345ms: UEsession: runSendGetDeviceInfo completed successfully 055486ms: UEsession: Device info: F5121 3580 1304-8560 R4E 34.4.A.2.19 055486ms: UEsession: getPhoneInfoResult recommended = 3 055486ms: UEsession: oldVersion = 34.4.A.2.19 055486ms: UEsession: getPhoneInfoResult single object id 055486ms: UEsession: Firmware with config and version 055486ms: UEsession: handleGetDeviceInfoResult no firmware found, probable prototype without login 055486ms: UEsession: ERROR in getPhoneInfoResult 055493ms: UEsession: runSendShutdown completed successfully 057282ms: UEsession: UE exited with 0 057532ms: UEsession: runTerminateUE process = ac4 057782ms: UEsession: runCloseLocalListener 057782ms: UEListener: Stopping server 057783ms: UEListener: Waiting for connections to clear.. 058133ms: UEListener: Pre-stop sleep 058484ms: UEListener: Stopping daemon 058484ms: UEListener: Server stopped! 058735ms: UEsession: runResetToIdle 058735ms: analytics: event = DeviceRepair / Failure / UEGetPhoneInfoMissingInfo 058735ms: UEsession: UE reset to error (idle) state 058735ms: UIState: UI devicerepair updated to errorFatal
But my phone is F5122,Why does it show F5121?
@Unregistered user
What was the original issue? did you flashed the phone? have tried again with XC?
I just want to upgrade to android 8.0 via repair
So you have the dusl SIM variant?
Is Oreo available for that yet?
