Battery health test
pseudonym
Battery health test
When I run run the battery health test, I received the following information. What does this indicate? I know what mAh means but I'm not familiar with uAh.
In my particular case, what would you suggest this number indicates? I'm not sure I understand how this number relates to the stated capacity of the battery.
Thanks
Lord_viridis
Deduct the last 3 digits,
Gives your battery capacity of 2783mah
3 REPLIES 3
Lord_viridis
Lord_viridis
Which is very good, as the advertised capacity is 2700mah
pseudonym
Thanks, viridis, I figured the first digits of the number were similar enough, but since it was over the official stated capacity, and that in an older phone, I had my doubts.
