Dobrý den,chci se zeptat jestli je Sony srs-x11 kompatibilní NFC s Huawei P8 lite?Předem děkuji za odpověď Pastora
"Hello, I want to ask if the Sony SRS-x11 compatible NFC with Huawei P8 lite? Thank you in advance for your answer."
Hi @Pastik and welcome to the community
The SRS-X11 should be compatible with any NFC compatible smartphone with Android 2.3.3 or later installed.
You can also connect with Bluetooth.
For more info have a look Here
