Model NWZ-B172, equalizer does not work. I have accidentally deleted Setup.exe program.
Could somebody send my this file? Thnaks
Hi @Andriy_Getya and Welcome to the Community
Are you sure you have deleted the setup.exe file?
(Did you format your pc or something similar?)
If not its still possible you have the setup.exe file in a backup folder made when you originally installed the software:
Thanks a lot for your reply.
But I did not install Walkman to PC. It worked without installation.
I opened Walkman Storage Media and deleted Setup.exe file inside ot Walkman.
Some music files were protected but the Setup.exe was not.
Now Walkman works OK but equalizer does not. It is written "cannot execute".
Thanks for getting back to me.
It could well be that if the bass is turned on then you can't access the equalizer.
Try turning it off and this should help.
