Vaio vgn-fe31m hidden partition problem
Dawido85
Hi all, I've got my vaio about week ago with windows mce. It's alright but I wanted to create recovery kit with vaio recovery utility and then came a problem. Vaio utility gives me a dialog box:
"Cannot start VAIO Recovery utility becouse the recovery partiotion has been deleted.
You need to use the Recovery Media Kit to recover your computer or restore the recovery partition.
For details, refer to the instruction manual."
I would like to use my recovery kit but I didn't have chance to do it :slight_smile:
Can I restore the partiotion? How?
In Partition Manager 8 Pro from paragon I see hidden partition so it isn't deleted :slight_smile:
13 REPLIES 13
rich912
Hi Dawido85 and welcome to the forum.
Have you by any chance installed Norton GoBack? If so you will need to temporarily uninstall this in order to create your recovery media.
Go n-éirí an bóthar leat
Dawido85
Hi Rich912, I didn't install Norton GoBack. I've already tried to unistall other norton stuff and acronis true image but that didn't help :slight_frown:
rich912
Hi Dawido85
Try the following
Start or restart your VAIO.
When you see the Sony logo, press F2 repeatedly to enter the BIOS.
Press F9 to restore the default values.
When asked to confirm, press ENTER.
Press F10 to save the configuration and exit the BIOS.
When asked to confirm, press ENTER again.
After re-starting, Click Start, All Programs, VAIO Recovery TOOL, VAIO Recovery Utility....
Dawido85
Hi Dawido85
Try the following
I did all steps but without any results :slight_frown:
profile.country.en_GB.title
kee-lo_
Member
Do you have any recovery media?
rich912
I would like to use my recovery kit but I didn't have chance to do it smile
Hi Dawido85,
I have escalated this to Vaio-Link as none of the usual solutions work in your case…
Dawido85
Hi Dawido85,
thanks man
rich912
Hi Dawido85,
Check your private messages...
Dawido85
checked :slight_smile:
