Hi !
Can anyone tell me how to connect a TV as output device to an PCG FR-215S ? If this works I would like to know where to connect (which type of cable) and which hotkeys to use.
Thank you.
Kann mit jemand helfen ? Ich möchte einen Fernseher als Ausgabe am PCG FR215S betreiben. Welcher Anschluß ist zu benutzen ? Wie muß das Kabel aussehen ? Welche Tastatur Hotkeys sind zu betätigen zum Umschalten ?
Vielen Dank.
Günter Kehrer:smileyhappy:
Do you want to watch TV on you laptop?
If you do what you need is a tv capture device that will plug in to a USB port. Hauppauge make some good products for doing this.
www.hauppauge.com
No, what I want to do is to show Powerpoints on a large tv screen ! (instead of buying a beamer)
I hope that the quality is good enough for powerpoints, I think for detailled views its not good enough anyway.
There is a gide to connecting the laptop to a tv in the online manual at
http://www.club-vaio.sony-europe.com/manuals/notebooks/FR215S-215M-295MP_H_UK.pdf
once there go to the connecting peripheral devices book mark and expand it then select connecting a TV page for a explination.
Hope this helps.
