I recently pruchased the above desktop over the weekend but have come to find a problem. I brought the PC home and set it up and came to install my ADSL modem which installed succesfully. I then try to install my BTopenworld CD to configure my connection, which encounters a problem straight from opening but continues to load the installer. Now, the installer says my computer doesnt meet the software's minumum requirements?
The CD requires a PII 233MHz and shows my PC has 33MHz It also says I have no disk space memory, RAM or recent USB connections
thus the reason it will not run.
IAnybody any ideas how I can solve the matter?
Kind regards,
David Bailey
Try and get the settings from them so you can do it manually.
yeah, I'm going to ring BT first thing tomorrow to see if they can.
I was just wondering if this would be a problem for future installation, games etc? I've put on photoshop, dreamweaver and office which are all fairly big programs and they've gone on no problem. Strange.
Yep, it's mainly the way BT made their software, it needs Java and uses MS' redunt Virtual Machine, which is a real pain. If you do a backup of settings once it's all working with the Files and Settings Wizard, you'll never need to put them in again.
