LCD backlight problem
vpillet
Hi all,
Before sending back my PCG-K115S to Carrefour (France) to repair, I would like to check about my LCD problem with all VAIO Guru here :slight_smile:
Here we are :
If I set the backligh to the minimum brightness using Fn+F5, the LCD
brightness start slightly to change by itself Intermitently.
The same behaviour when a light bulb is ready to crash. This is very annoying.
If I set the brightness to middle or maximum value, everything is OK.
I guess this is a harware problem regarding the backligh ...
Any experience or help ?
Thanks all,
Vincent.
profile.country.en_GB.title
kee-lo_
Member
Hi Vincent,
Yes I would take it into Carfour (bonne chance).
They might well tell you VAIO Link will have to repair it.
