Issue with function key S1
Toschiva
Hello !
I have a problem with the function key S1.
When i press the button the options menu for the function keys open !!! i have entered the right folder... tried other programs, but dont work. key S2 is working fine...
I have a Sony Vaio VGN FE 28B. Vista installed.
Got this issue with XP too. I have installed all drivers, with the right sequence.
Could someone pls help me ??? :thinking:
:thinking: :thinking: :thinking: :thinking:
7 REPLIES 7
MattWilson
Welcome to ClubVAIO :slight_smile:
Can you try setting S1 to "Launch Application" and for the application use the path C:\Windows\System32\Notepad.exe
Apply it and then press S1.
What happens?
:thinking:
MattWilson
Here is what it should look like:
Toschiva
thanks for answer !!!
I know how to configure the keys, because the S2 key is working good !
hmm... dont know what to do... 😐
MattWilson
For windows mail "Arbeitsordner" needs %userprofile% written in it. Then it should work fine.
:slight_smile:
Toschiva
:slight_smile:
hm dont work... : (
I just cant put this in, but the key S2 is working good !! Doesnt matter which programm i set, it will start when i press the button. S1 starts the Configuration... :thinking:
MattWilson
Try reinstalling the utilities for your VAIO and see if that makes any difference.
Preinstalled Utilities (XP) for Vista install from upgrade DVD
Extract the Zip folder to C:\utils and install in this order:
1. Sony Utilities
2. Sony Shared Library
3. VAIO Event Service
It can only be a software fault as the button appears to work.
:slight_smile:
Thalamus.
Hi Toschiva
As you've upgraded to Vista use the links below to download the required utilities for your FE28B...
1 SonyUtils DLL
2 Sony Shared Library
3 Vaio Event Service
4 Setting Utility Series
Once downloaded install in the same order as above, then re-boot your vaio.
You may have to do this more than once.. :wink:
