HI
I WILL BE GREATFUL TO U ,IF U HELP ME OUT
I WNAT TO CONNECT MY SONY VAIO VGC-M1 DESKTOP TO LCD TV
MY VAIO HAS FOLLWING CONNECTIVITY
2
x headphones - output - mini-phone stereo 3.5 mm
1 x IEEE 1394 (FireWire) - 4 PIN FireWire
1 x TV antenna
1 x audio - line-In - mini-phone 3.5mm
1 x microphone - input - mini-phone 3.5mm
1 x modem - phone line - RJ-11
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
5 x Hi-Speed USB - 4 PIN USB Type A
1 x audio / video
1 x display / video - composite video input - RCA
1 x display / video - S-video input
2 x audio - line-In - RCA [/font[/size] ]
WHAT WILL NEED TO CONNECT MY DESKTOP TO LCD TV
SHOULD I NEED A SOFTWARE ETC
MANY THANKS
HARI
HI
2
1 x TV antenna
1 x audio / video
MANY THANKS
HARI
Hi hanudoc and welcome to Club Vaio.
Unfortunately, your Vaio is not designed to connect to an external screen. All the connections are INPUTS only - to display other equipment signals on your Vaio screen.
The only way you can get a video signal out of your Vaio M1 is through the USB Ports. This will not give a very satisfactory picture.
Have a Google for "USB to TV" to see if you can find something suitable. The only one I can find is very expensive: -
Studio Moviebox
hi
many thanks for the reply
i also noted that my desktop has a PC CARD slot
can i use that to connect to lcd tv/monitor
many thanks
