Hi! What to do about these blue screens? They keep on happening once in a while. It could be anytime, just after startup or after a couple of hours. Any ideas?
/bontempi
Which blue screen?
These are normally caused by third party software and drivers. You need to read the error message on the blue screen. To do this you must turn off the automatic reboot option.
1. Click Start button.
2. From Start menu Click Control panel.
3. In Control Panel Click the System icon.
4. In the System Window look on the Left hand side of the window and you will see a list of options. Click on the Advanced System Settings option.
5. Because Computer management requires administrative privileges you may find the User Account Control will pop up. If it does then enter the required information (if you are not the administrator) or, if you are the administrator, click the Continue button.
6. In the Advanced Settings window look for the Startup and Recovery section and then Click the Settings button.
7. In the Startup and recovery window look for the section marked System failure and remove the 'tick' mark from the 'Automatically Restart' option. Now press the OK button.
8. Finally click the OK button on the System properties Window and then close the system window.
What is the program listed on the BSOD?
