Hello,
I had to install WinXP on my FE41Z which was quite a struggle with respect to finding the appropriate drivers.
Now I found most of them, except the one for the LCD screen. Atm I can only choose "Plug & Play Screen" with 60Hz, which isn't very eye-friendly.
Moreover, I missing the right utility or driver for the touchpad. The scrolling function (moving up- and downwards on the right side of the touchpad) seems to be disabled.
It would be great, if someone could help me or tell me where to find the appropriate drivers.
Thanks in advance!
Hey Caladris
Have you tried downloading drivers from the support page of the older fe models which came with Windows XP pre-installed , i imagine these should work fine and fix any potential problems
Hope This Helps
Hello Matty,
thanks for your answer. Yes I tried to use the drivers of the FE31Z model, which comes with WinXP. But I coudln't find any .inf or setup.exe for the screen.
Also, when I try to use any of the .exe files in the "pointing" directory (hoping one of these installs the touchpad drivers), I get the error message "DLL could not be opened".
And when I use the DPinst.exe of the FE41Z Drivers, it tells me that the Alps Touchpad driver is not required since there is no such a hardware.
So right now I am quite clueless
