I have just bought a Vaio VPCEB2C5E. On the delivery note spec it says e-SATA/USB and above the port itself it says eSATA followed by the USB symbol. Therefore I am assuming if it says "USB" that it is a powered combo port that will work with the new Seagate GoFlex portable drive combined with its eSATA upgrade cable (which states it will only work with a combo powered eSATA port and not a standard eSATA port).
Anyone know how I can find out whether the eSATA ports being put into new Vaio's are definitely the "powered" version?
Hi Andy,
I believe ALL USB/eSATA ports are 'powered': -
http://newmodeus.com/shop/index.php?main_page=product_info&cPath=17&products_id=235
Although it does say that you cannot use both USB and eSATA at the same time - it is in fact two ports with the four central contacts for USB/Power and the new 4 outside contacts for eSATA. You will need to set the access mode to eSATA as it will not work in IDE Mode.
Hi Andy,
Thanks very much Blencogo, the link does seem to confirm that.
Apologies if this sounds thick but how do I "set the access mode to eSATA"?
I think you should be OK.
Some earlier USB/eSATA ports would only connect using eSATA if the hard drive in the laptop was set to eSATA mode.
Ignore this it should work OK.
Thanks
