Driver problems with Vaio VGN-FE11H
eugenvaio
Hello! I have a Vaio (VGN-FE11H) and I have a problem. A big one made from smaller ones.
Let’s start with the beginning. I have deleted all the partitions; I have recreated 3 new ones and installed the OS. Before that I saved the Drivers folder.
Now, the problem is that I can not install all of the missing drivers. In the Drivers folder not all of them have a setup routine, so some of the must be installed manually. The question that I encounter is how I do that, because not all of them ‘want’ to be installed.
Please help me because this is a awful situation. Not even the sound card is working.
Thanks.
PS I also downloaded the drivers from Sony’s website, but they are the same. Can anyone give me the detailed specs so I can search for the drivers? Or maybe I am not the only one in this situation? Maybe some of you were put in a similar position and defeated it.
:wink:
11 REPLIES 11
eugenvaio
I've managed to install a few other drivers, but the audio and modem ones still give me headaches. Any ideeas, because they have executable installers, but generate error (in case of the audio driver - Sigmatel, 'Device object not present, please restart and try again') or nothing (in case of the modem - Soft Data Fax Modem with SmartCP by Rockwell/Conexant).
Any ideeas!
GattoMatto
You can use the "try an error" method. Try to look your hardware that gives a problem (from hardware manager) and try to change drivers from there indicating folders where you suppose the driver is. I have managed in this manner to install almost all the drivers when have tried to install another version of OS.
profile.country.es_ES.title
rosoria67
Hi,eugenvaio,what you have to do to install drivers without setup routina is: go to start/control panel/sistem/harware/device manager,selec the dispositive you want update (it is in yellow ?, propieties, update driver, and look for in the folder you got drivers.
Excuseme for my bad english (I´m spanish)
rosoria67
For the audio problem that you got, look for a sound pach in foro,and first of all install the pach and then the sound driver.
It works ,I did it and it worked.
Best regards
rich912
Hi eugenvaio and welcome to the forum.
This thread may provide some clues...
Go n-éirí an bóthar leat
eugenvaio
Thanks Rich912, I am now downloading the needed patch and I hope for the best. I will revert with what I manage to do as soon as posible.
Thanks! 😉
rich912
Fingers crossed......
eugenvaio
I don't know how, but the modem is now installed. And the audio... is not. 😞
Do you think that instaling more patches would help (I mean something like AutoPatcher)?
IT WORKED AFTER SEVERAL RESTARTS!!!
THANKS! YOU ARE A TRUE VAIO MASTER!!! :slight_smile:
rich912
:slight_smile: I am pleased to hear that the problem is solved, but thanks go to the original poster – I just provided the link……
