Recently installed pocket Vaio. I can access the hard drive by using the desktop, but when I launch Sonic Stage or Music Transfer - it states "not connected"
Sometimes I get "USB device not recognised" in the taskbar, although the computer still shows "removable device"
I am using Win XP with sp2
can anyone help please?
I HAVE THE SAME PROBLEM!! PLEASE HELP US!
I cured mine - it was giving me problems because I upgraded the firmware, but didn't bother to upgrade Sonic Stage and transfer....once I did this everything works....
My computer has xp prof. Service pack 2 has been installed at a later stage. When puting the cd to install the sonic stage the computer can not run the exe program for the installation. The cd is ok because I tried it in another computer which does not have service pack 2. Can any one help me on how to solve this problem ?:smileycry:
I had trhe same problem as you!! I managed to fix it be re-initializing the player to the new sonicstage install.
If you're in the U.S. you can simply authorize your player at the online store. The rest of the world must use the initialisation proceedure.
use the on
The fault actually has nothing to do with the player not being "recognised". It's to do with licence management. I think dodgy error message is the result of bad translation.
My full post on this fault can be found
here .
Hope this helps :).
