Can't set up wireless network between Vaio WXPProSP2 and a W98SE PC
petermilewski
I set up a wireless network between my S2XP and my earlier Vaio, both with WindowsXP Pro SP2. It works fine. But I couldn't do the same with my Windows98SE PC - though there is already a satisfactory wireless network between my old Vaio and the Windows 98 PC. After testing (Net Diagnostics and ping, etc.), I found that my S2XP couldn't ping either itself or the PC.
Then the problem got curiouser and curiouser. I got the wireless network between the two Vaios running. No problem, working well both ways. Then I did Net Diagnostic and ping tests on the S2XP. Same failure!! It can't ping either itself or the other Vaio - even though the Network is working fine. In other words, it appears as if TCP/IP on my S2XP is not working - yet the network still functions.
Does this mean that the two Vaios with XP Pro are using some other protocol than TCP/IP to communicate, but poor old W98 can't do that?
Should I reset my TCP/IP settings and try again? Any ideas?
3 REPLIES 3
profile.country.en_GB.title
kee-lo_
Member
If you have a firewall check it's allowing access to the Win9x machine
petermilewski
Thank you. Both the Windows and Norton (bundled software) Firewalls are turned off. Any more ideas?
Eugenepang
did you try to used a network cable first? to see if its working? instead of just using wireless?
