Does anyone know how to get the camera to work?? I lost mine when I clean-installed Vista some months ago.I have tried the various driver and utility updates but no luck
Hi iansomm and welcome.
Is the camera showing as installed in Device Manager? Under "Imaging Devices" it should show as a "Vaio Visual Communication Camera VGP-VCC?". If it is not installed, you need the original XP Driver that came with your Vaio (same driver for XP and Vista).
In C:\Program Files\Sony\Vaio Camera Utility check the Version.txt is Version 2 (for Vista)
In C:\Program Files\Sony\Vaio Camera Capture Utility check the Version.txt is Version 2.2
Check you have installed Microsoft Hotfix KB931812
