Can anyone help, I am looking to buy a bluetooth enabled printer, does this mean to say I can print from my Vaio bluetooth with no wires?
Anyone know?
Once you have paird your printer with your vaio, yes you should be able to print without wires.
COOL!
I would still have to load the printer drivers on to the Vaio yes?
I am finding it difficult getting my head round how this would work, when I use my Vaio the mouse is detected as bluetooth if I then switch on a bluetooth printer what happens? is there a bluetooth contol panel listing all bluetooth devices?
Hi
You should have 'Bluetooth Devices' in your control panel. This will configure all Bluetooth Devices. Once you have set your devices up, they should be discovered automatically.
You will have to install the printer as a 'Bluetooth Printer' - (Add a Printer in Printers and Faxes).
:smileycoffee:
put your printer in detect mode, and try to make a connection using your notebook. It will ask for the correct drivers. Read the manual of your printer, as this will tell you how to install.
HP DeskJet 995c can do bluetooth
Canon have a wifi enabled printer ( if used with Wireless Access Point) Canon Pixma iP5200R
