hi guys !
i just placed my 202 in a different room than my tv is and now neither my keyboard nor my remote is working properly.
the infrared receiver is in the same room as the tv , but i don`t have any controll.
if i open the door between the rooms , it works more or less , but the infrared receiver seems not to be working.
if i unplug the infrared cable it stays the same, so there must be something wrong with the receiver 😕
is there any way to activate the IR ports on the back ?
any ideas ?
Hi Nti.
Which model do you have?
PCV-RS202
PCV-RX202
PCV-RZ202
VGC-RC202
VGX-XL202
Just explain the set up with the Infrared Receiver and the Infrared Cable - is there a wire to the Vaio in another room?
sorry , if it wasn`t clear.
i`m useing a vgx-xl202.
the pc is in one room , the IR cable + receiver is pluged in (infrared transmitter out) and is leading to the other room , but my remote is not working. 😞
i checked if there is any option to enable the infrared connector but i couldn`t find anything , not even in the Bios.
i`m running Vista 32.
Ah - I see. I think the Remote Control will only work if you are in the same room as the Vaio.
I think the Remote Control IR Receiver for the Vaio is in the front panel of main unit of the XL202 (Front - top left). I presume the IR Reciever you are talking about is the "IR Blaster" which is only useful to change the channels on a set-top box with the Media Centre Remote.
ah , i see , now i userstand.
so i guess i have to put it back on the same room with the tv -.-
1000x thx
Jan
