Hi Team,
My Sony Xperia Sola is not getting turned on post master reset. I am trying to flash the phone. However "Emma" Application says my phone is locked. Is there any why where I can unlock it? When I search in Google I could only see the steps that can be done post switching it on. As of now I am not able to switch on my phone itself
Please help me.
I have tried connecting the phone with PC suit software. But no luck as my phone is switched off.
If your phone is or was locked to a carrier/network branded there's nothing you can do there as networks/carriers request the bootloader to be locked
As of now I am not able to power on my phone itself.. If I try power on it showing "Sony" then its coming to "Xperia" (This is usual thing) post to that its keep on showing only "Sony" and "Xperia"
unable to do anything
Thanks guess its downloading.. Let me confirm soon
SUS should fix your phone
I downloaded SUS but the software does not list experia SOLA model.
Wahts wrong??? plz help
You need to run SUS in compatibility mode with windows 7.
Oh Thankx.!!!!!. i was trying in windows8.
Will try with Win 7.
You can run it from W8 also,by running in compat mode.Do you know how to do that?If not,go on on windows 7.
