Xperia S wont Power on/Start
ANUP1
Hi All,
I have serious issue with my xperia S. Phone wont start, no vibration, no led light, nothing.
Issue occured when i was trying to update the phone.
Tried recharging, etc...
Please help.
Regards,
Anup.
Thommo
Genius
If it's not turning on then try holding power and volume up untill you feel 3 vibrations 1 after the other not 1 on it's own - Then try turning it back on if you still have no luck then you will have to run a repair using SUS found here emma.extranet.sonyericsson.com/update_service_setup download and install and follow the on screen instructions - This should repair your phone as this works in flashmode and not normal mode like PCC does to begin prior to rebooting in flashmode
2 REPLIES 2
Thommo
Genius
ANUP1
Hi Thommo,
Your solution has worked, it worked with Poweron + volume Down as well as Poeron +Volume UP.
The issue occured beacuse phone was not properly updated. Now phone is good with latest update.
But one thing i dodnt like was that after the update i lost all my installed apps and contacts. Also there is no option on xperia S to save numbers directly to SIM , only import/export option is there .
Thank you for your response.
Regards,
Anup.
