Just wondering if anybody knows how to adjust the alarm volume on the Xperia S or if the feature to do so even exists ?
Thanks
Set your alerm, go to advance setting right bottom of the alarm setting.
You can adjust it.
Thanks for that.
Can't believe i overlooked that one.
Cheers.
when I go to advanced settings I can only write text. When I push the right button nothing happens,. Do you know another way? txs
The Text is just a remark for your alarm setting.... like a reminder.
For volume setting, you can check on the 'alarm volume' which you can set your volume 'high low'.
If you mean for changing the ring tone, go to the style setting, you can add a style and a ring tone you need for your alarm. Hope this can help.
