Xperia Ray (ST18i) Update 2.3.4 4.0.1.A.0.283
Special Thanx to Jozinek from the XDA Forum
http://forum.xda-developers.com/showthread.php?t=1271512
Xperia ray Android 2.3.4
32 REPLIES 32
yes you do
I have done the update successfully.  Most of the thing is fine but I can't get the ip address from the WIFI access point.  Wonder if anybody got this problem and any solution?
Thanks in advance!
VNW
I think you have a similar issue as this
http://talk.sonyericsson.com/message/113302#113302
Thanks for your tip!  I have tried to set the wifi without security but still can't obtain ip address normally.  Didn't try static ip address because it is not practical for doing.
Anyway, thanks!
Thanks for this manual, but I have some problems with flashing.
I already flashed my Ray accordig to this manual with CyanogenMod 7.1: http://wiki.cyanogenmod.com/wiki/Sony_Ericsson_Xperia_Ray:_Full_Update_Guide
But know I want to go back to SE firmware, but the flashtool won't recognize my Ray (but Fastboot does). I can't post you any error messages, because there isn't even one. Flashtool is just waiting at step 4 with this animated picture.
Is somebody facing the same problem?
Does this root your device?
Do you need to unlock Bootloader first, if yes how?
Thx
this is how to root your Ray
http://forum.xda-developers.com/showpost.php?p=16659481&postcount=33
just out of curiosity, why do you need to root your phone?
I'm new to Android so I'm not fully familiar with all the terms.
I don't need to root my phone as such but I would like to update to Android 2.3.4.
I have read a thread in this forum referring to this thread for debranding.
And I thought that you had to root your phone for debranding, that's why.
Hi all,
I failed to upgrade my xperia ray.
ERROR-Please install or reinstall device drivers from drivers folder.
Help me please...
slimshaddy
Hero
do you have both pc companion and update service installed on your computer..
they are necessary..
