So when I was in gingerbread, whenever I needed to type in either Chinese or Japanese, I could just tap and hold down on the text box (either in SMS or any forms of text box), but now tap and hold down on the screen no longer gives me that option.. and when I go setting for typing I could not find the original Chinese and Japanese inputs..... anyone got any idea?
While using keyboard drag down the notification bar and select input method
Thank you very much sir =]
how to remove that notification,whenever i type on text field it always shows up..i want it to be hide
I don't think you can... Beside, it's only a little square on top anyway, not really bothering me.
its not little..mines always shows on notification,,its like a message that always shows on notification whenever i type a message.,,and also i have a problem with the lockscreen, the volume wont work if im on lockscreen,,i need to unlock it just to make my volume key to work..
Volume key is not supposed to work when screen is locked and
regarding that notification it will always occur while using keyboard
how come when i was in Gingerbread i can use my volume key when im on lockscreen,,but anyway thanks maybe its a downside.
Can you elaborate which volume are you talking about ?
nevermind it was already fix..
all my problem is the notification led now isnt working well..
