I updated my phone last night. The PC companion showed that its updated successfully.
I Pressed the power button to turn on the phone, it vibrated and stared. After that it showed android upgrading screen. Then the screen turned off and notification light blinking red continuously. I waited for few minutes and nothings happening. So I pressed the power button again to turn on the screen. When I press the power/lock button to start, the red notification light blinked 3 times and stopped. Now even if I press the power button again, same thing, blinking 3 times is happening.
I have not rooted or unlocked the boot loader.
Please help me.
I suggest you to charge your battery for sometime ( 1 hr) (red led = low battery) and if the results are same then charge for 2 hours and -
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
or
