Xperia Neo V ICS 4.0.4
Hello Guys...
Sony Ericsson has finally autorized the official ICS 4.0.4 update in Brazil...
And the question is: IS IT WORTH TO UPDATE FROM GINGERBREAD?
I like to play games sometimes, hardly ever from gameloft (i read that a lot of them were not working on ICS), and does it affect the duration of battery or slows the cellphone?
there is a significant lag with the launcher, dialer and some apps, you can always downgrade
you have 2 options
1) take it to a sony repair center
or
2) manually downgrade
http://talk.sonymobile.com/thread/44888
3 REPLIES 3
you have 2 options
or
Thanks, so, its not worth to upgrade?
Does it suport Ad hoc network?
there's only one way to find out if it's worth it or not, you should try it
