Xperia Mini Pro Won't Update!!!! Phone is dead!!!! Need Help!!!
Hello
I tried updating my phone with pc companion and it failed. It only got 50%!!!
Now my phone will not turn on. It won't flash with the service tool or pc companion or the flash tool from XDA!!!
Is my phone faulty? If not what can I do???
Thanks.
in that case you should return it, it might be a faulty device
21 REPLIES 21
boyzrulz52
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
update using above software and u dont need ur mobile to be turned on, just press the volume key when u connect the usb cable and this is official update only,but manual .
does the phone charge when you connected to a PC? if it does then Update Service or Flashtool should fix it
Non of the above worked. I have already tried it.
How can I find out if the phone charges if it won't power on?
Thanks.
Log from flash tool.
30/059/2011 15:59:00 - INFO - Device connected in flash mode
30/059/2011 15:59:04 - INFO - Selected SK17i_4.0.2.A.0.42_(1249-8051) (2).ftf
30/059/2011 15:59:04 - INFO - Preparing files for flashing
30/059/2011 15:59:06 - INFO - Searching Xperia....
30/059/2011 15:59:06 - INFO - Found at USB\VID_0FCE&PID_ADDE\5&17F63C8F&0&3
30/059/2011 15:59:06 - INFO - Start Flashing
30/059/2011 15:59:06 - INFO - VER="R9A028";DATE="20110516";TIME="12:32:00";
30/059/2011 15:59:06 - INFO - Flashing loader
30/059/2011 15:59:08 - INFO - PROT_VER="03";DATE="20110217";TIME="15:47:00";VER= "R4A066";CXC="1234-5769";TYPE="S1_LOADER";UNIQUE_DEV_ID="9342E9503937 8453AE302274289E740295283FB1";SEC_LOCK_STATUS="LOC KED";OTP_DATA="4B6D7100471404C815080428403928A7B00 1002000000000";IMEI="XXXXXXXXXXXXXXXX";AID_VERSION ="0004";EROM_AID="0001";LOADER_AID="0001";SW_AID=" 0001";CUST_AID="0001";SIM_LOCK_AID="0001";HWCONF_A ID="0001";PROD_ID="0001";ACTIVE_LOADER_AID="0001"; MEMDEVS="02:00:0098:00B3:0055:00002000:00020000:00 000800:00000040,03:03:0003:5344:0080:0001D780:0000 4000:00000200";MAN_ID="0098";DEV_ID="00B3";EXT_DEV _ID="0055";SIN_VER="0001";AID_TAMP="NOT_TAMPERED"; MAX_PKT_SZ="00010000";AUTH_LEVEL="NONE";AUTH_MET=" 0001";CARD_PRESENT="YES";CARD_SIZE="2GB";CARD_DATA ="UHJvZE5vPTEyNDktNjA4MQ1Qcm9kUmV2PVIzQQ1Db3BpZWRC eXRlcz02Nzc0Nzc5NTENQ29waWVkRmlsZXM9MTY4MzgNQ29waW VkRGlycz0xMDcNT3JkZXI9MzAwNjUwMDI2NzcN";LOADER_ROO T="S1_Loader_Root_773f";EROM_ROOT="S1_EROM_Root_d6 01";SW_ROOT="S1_SW_Root_883f";CUST_ROOT="S1_Cust_R oot_9603";SIM_LOCK_ROOT="S1_SL_Root_c422";HW_CONF_ ROOT="S1_HWConf_Root_08af";BIM_STATE="DISABLED";
30/059/2011 15:59:09 - INFO - Flashing adsp.sin
30/059/2011 15:59:12 - INFO - Flashing kernel.sin
30/059/2011 15:59:15 - INFO - Flashing amss_fs.sin
30/059/2011 15:59:15 - INFO - Flashing fota1.sin
30/059/2011 15:59:16 - INFO - Flashing fota0.sin
30/059/2011 15:59:16 - INFO - Flashing apps_log.sin
30/059/2011 15:59:16 - INFO - Flashing amss.sin
30/059/2011 15:59:29 - ERROR - Error flashing. Aborted
30/059/2011 15:59:29 - INFO - Now unplug the device and power it on
30/059/2011 15:59:29 - INFO - Then go to application settings
30/059/2011 15:59:29 - INFO - turn on Unknown Sources and Debugging
Thanks,
if you connect the phone to the charger or the computer the LED should turn yellow/orange/green
The light turns green when I plug it in to the usb on the pc, when not in flash mode. When I connect it to the charger, nothing happens.
Thanks.
ok, good news then you can use Flashtool or Update service, what happens when you use Flashtool and it ask you to connect your phone on flashmode? it doesn't detect your phone?
if it doesn't then re-install PCC and SEUS on your computer then run Flashtool again
I have tried flashtool.
It detects the phone, begins the update but fails at certain intervals.
Sometimes it will fail when flashing the kernel.sin file but it never gets past amss.sin.
See my log above.
Thanks for your help so far. But I am thinking the phone is faulty, or the usb cable.
I think it's the USB cable
