I need help with my xperia ion lt28h..
After installing a .zip (Smooth ion) through CWM Recovery, my phone restarted n booted up normally to the lock screen. After i unlocked the screen, it went blank so I pressed the power button and the normal power off button (and some others) appears, so i power off the phone and it went to a boot loop.
I tried pressing the Volume up + power button and connecting it to flashtool by pressing the volume down button and inserting the usbto flash a new firmware but nothing appeared on flashtool
I tried the Volume up + power button again and again and still nothing.. I then pressed Volume up + power button again but longer and received 2 or 3 vibrations (i can't remember) and now the phone is just Dead. No Screen,No LED light, nothing :'(
I tried charging it for 2+ hours and tried connecting it to my pc to see if it does anything but apparently nothing happens.
Somebody please help me :'( This is my only phone and I have no other
Xperia ion LT28h
Firmware: 6.0.F.0.72 (LT28i 's Firmware)
Bootloader: Unlocked
And Rooted with Busybox installed
I know this is not the exact place to ask for help, but i'm really desperate
Pretty much happy to hear about it.
As I mentioned on the first page, it really takes a lot of time to charge when bricked.
Anyways patience was all you needed
Thanks for updating the thread.
@Nabeel>>
i have the same proplem .. and i left my my pاone charging for >30hrs now and the led-bar is still blinking red
,, more than 10hrs blinking red and didn't get the solid led till now ,,
iam really hopless and idk what to do..
Could u help me please?
now got solid red LED then bootloops
and i can't flash a firmware through these bootloops neither via flashtool nor via SUS..
so plez someone tell me what to do ,, or how to flash the firmware ?
1) don't worry ,just connect charger for full night even if the phone does not show LED
2)disconnect your phone ,if connected to PC .
3)start flash tool,click flash icon ,select flash mode,select flash file Fit start flash
4) when asked to connect phone in flash mode ,just connect phone without doing anything your phone will detect by flash tool and starts flashing the phone
Start flash tool without connecting phone to PC
after that it will ask to select flash file ,just select ,after that one window prompt to connect phone in flash mode ,
just connect phone to PC and sit back ,it will recover your phone
@Shree
flashtool doesnt detect mob during bootloops..
and also when it's switched off can't be detected by the flashtool
@Shree i left it charging ~2days
~30hrs no LED
~10hrs Blinking red
~2hrs solid red
then bootloop started
boot loop for aminute then it turns off i put it charging for 10 mints then bootloop starts,.. and so on
i try to flash when it's switched off flashtool doesnt detect it
also when i try to flash during bootloop flashtool doesnt detect it.
so idk how to flash both ways my ion is not detected by flashtool
MY ION WORKS AGAiN
using rubber band trick
http://forum.xda-developers.com/showpost.php?p=37562298&postcount=301
http://forum.xda-developers.com/showpost.php?p=37844592&postcount=317
Hi Nabeel,
My phone went to hard brick again!
I've tried everything but now as I wait for it to get flashed ( With RubberBand Trick and Red LED shows) the flashing won't start but the phone itself will start and go to a bootloop.. I got this at the Flashtool command
20/049/2013 20:49:34 - INFO - Selected LT28h / 6.1.E.3.7 / CE
20/049/2013 20:49:34 - INFO - Preparing files for flashing
20/049/2013 20:49:59 - INFO - Please connect your device into flashmode.
20/058/2013 20:58:47 - INFO - Device connected with USB debugging off
20/058/2013 20:58:47 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/058/2013 20:58:52 - INFO - Device disconnected
20/059/2013 20:59:00 - INFO - Device connected with USB debugging off
20/059/2013 20:59:00 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/059/2013 20:59:05 - INFO - Device disconnected
20/059/2013 20:59:13 - INFO - Device connected with USB debugging off
20/059/2013 20:59:13 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/059/2013 20:59:19 - INFO - Device disconnected
20/059/2013 20:59:27 - INFO - Device connected with USB debugging off
20/059/2013 20:59:27 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/059/2013 20:59:32 - INFO - Device disconnected
20/059/2013 20:59:40 - INFO - Device connected with USB debugging off
20/059/2013 20:59:40 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/059/2013 20:59:46 - INFO - Device disconnected
20/059/2013 20:59:53 - INFO - Device connected with USB debugging off
20/059/2013 20:59:53 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/059/2013 20:59:59 - INFO - Device disconnected
20/000/2013 21:00:06 - INFO - Device connected with USB debugging off
20/000/2013 21:00:06 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/000/2013 21:00:13 - INFO - Device disconnected
20/000/2013 21:00:20 - INFO - Device connected with USB debugging off
20/000/2013 21:00:20 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/000/2013 21:00:26 - INFO - Device disconnected
20/000/2013 21:00:34 - INFO - Device connected with USB debugging off
20/000/2013 21:00:34 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/000/2013 21:00:39 - INFO - Device disconnected
20/000/2013 21:00:47 - INFO - Device connected with USB debugging off
20/000/2013 21:00:47 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/000/2013 21:00:52 - INFO - Device disconnected
20/001/2013 21:01:00 - INFO - Device connected with USB debugging off
20/001/2013 21:01:00 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/001/2013 21:01:06 - INFO - Device disconnected
20/001/2013 21:01:13 - INFO - Device connected with USB debugging off
20/001/2013 21:01:13 - INFO - For 2011 devices line, be sure you are not in MTP mode
20/001/2013 21:01:19 - INFO - Device disconnected
Then my phone offsby itself back to the Red LED part..
What should I do now?
