Last Night,i was flashing my phone with an original rom before 6.1.E.3.7
Then suddenly The flashing failed and i didint read the passage carefully and My whole phone just keep boot looping,I was scared im planning to shut it down and flash again.but it didint work the boot loop i tried the Vol Up and power and it did nothing
Then I pressed it longer(Vol up+Power) It came out a green LED but the screen was turned on but its blank I tried shutting it down but its impossible
So,In the Evening The Battery All Drained Out But When i took it to flashtool it wont run and when i charge it has a red LED straight away
its different from all of the other Bricked phone now its still charging i have been charging for 12 hrs straight Any help Ty
mitch32 No point getting angry.
Remember , it was you who flashed the phone and caused all this.
So can you exactly tell me what were you flashing ?
How did it all end up in brick ?
Now did you flash ?
What happened after you flashed ? was it successful ?
Battery low was the reason flashtool didn't recognize your phone.
Now that you've charged it enough, try to flash using flashtool again and it should work.
k,but im charging for 15-17 hrs and the LED was still red any Hope?? thank you for replying i was waiting for a reply from someone especially u,and last time i charged until a state where the boot looping continued and i cannot stop it so i didint sucessfully flash it
please teach me what to do now,i follow some forums and it says that(wait for the LED to go green or wait for the LED to vanish then try to flash again but Ive been waiting for 17 hours already and im scared my phone will die That my only phone that my father bought for my birthday please help nabeel
Don't panic mate.
Have a look here
http://talk.sonymobile.com/thread/126426?start=0&tstart=0
Read everything carefully.
Hi nabeel its been 24hrs++ still no hope =.= if 30 hours no hope ill sent u more info ty
Ohh yea i forgoten if i went to sleep and the phone's LED is gone will it be fine?
Yeah there's no problem
I think you should try flashing now.
Before flashing do a force shutdown ,and do not try to switch on your phone.
Press and hold the power button + Volume Up button for 10 Seconds > ( 3 Vibrations ) Force shutdown
But the red LED is not gone yet u wan me to flash now??
Nabeel ill go to sleep and see what happens tommorow if the LED is not gone ill update the statys thanks for ur help BTW
nabeel im flashing the firmware since the LED was gone but it came out a red LED
now what??
