Xperia Go can't enter fastboot mode
elshah
Im trying to unlock Sony xperia Go right now.... it wont stay on fastboot mode ( volume up + plug usb) when i press volume up, the light strip turns blue for a second or two, but then goes into charging while shutdown mode... I check *#*#7378423#*#* -- Service info > Configuration > Rooting Status it says - YES// I try USB debugging ON and OFF... Battery 95-100% charged... What i do wrong?:smileycry:
elshah
ohh, nevermind, i got it working right now, i just installed the S1 Fastboot driver from the flashtool driver and its working like a charm right now.l
7 REPLIES 7
elshah
anyone? help me please? i want to install cm11 right now. pleaseee.
elshah
nheo-bhert
may i know we're you get the S1 Fastboot driver?
elshah
download this and install it . link : http://www.flashtool.net/download.php
after finish install go to local disk c >flashtool>drivers. you will find flashtool-driver inside there. open it and find Fastboot Driver and tick it. After that install it. Slightly_smiling_Face
SpirosM
Man I am despred! Neather that worked.. I tried installing it but it couldn' t complete the installation..  Slightly_frowning_Face
Anyone can possibly help me ?
elshah
Did you click yes on all windows prompt? I think the installation won't have any problem. Try install it back.
fire51phil
Hi, not sure if you still need it, but what OS you use on your PC? if windows, i cant with iOS Slightly_smiling_Face
