Hello, today i noticed a hairline crack in my xperia arc. It is right next to the volume down button , and I have never dropped it , actually i keep it in a case and take good care of it. Is it covered by the warranty ?
(xperia arc l15i misty silver)
I think that you will have to check that with your local support team. I haven't heard that it should crack there. Give your local support a call or E-mail.
I had an issue with my Arc S. which was manufactured around April/May 2012. It was fine for around 6 weeks until I used a Sony Ericsson authorised case. It was this case that put pressure on the two lower corners of the handset. Removing and placing the phone in this case involved some force which caused the cracking. I remember the Xperia x1 also had an issue with cracking.
Ok. Thanks
