Hey today i had a problem i was updating my today built xperia play as my computer turned off!! Now, when i try to turn the phone on, first comes there SONY ERICSON and then it does again and again and again.What can i do'
Backup everything then repair it with
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this is how to backup
Settings -> privacy -> Back up my data and Automatic restore should be selected
don't forget to mark the Correct & Helpful Answers
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
and ake sure you have stable connection of the computer also..
Works!! Thank you very much!
Anytime
Hahahahahah nice
