Wifi is not working on my xperia mini. I have restored it too default settings and had done software again on it. But the problem arises same. Please help me out. Thanks in advance.
Have you checked all the tips in the sticky thread about Wi-Fi? Check the router settings as suggested in the link above.
Can you please provide a bit more information regarding in what way it if not working? For example, does it not turn on, does it not connect to a router or does it not scan for routers etc.
Hi it does not scan for the routers thanks
Try running a software repair on the phone using PC Companion.
www.sonyericsson.com/pccompanion
You can also find Wi-Fi tips in the sticky thread: http://talk.sonyericsson.com/message/154244#154244
Let me know how it goes.
I have alreeady said that i have done software 2 times. But it is not working. I have done once again after u replied but the problem is the same. Please solve it as soon as possible. Thanks in advance.
Thanks . It works now
