Hello sony, I have a Sony Ericsson live, somehow my laptop does not accept internet connection when I turn on Wifi teathering, but if I use the internet via my Live with walkman, all is fine ... the information on my laptop is "NO INTERNET CONNECTION".
what should I do to make it all back to normal? (my country is Indonesia)
Thank you for your answer, i've brought my Sony Ericsson Live to Sony Xperia service center in my country, after my phone checked for two days,they replace my phone with the new Sony Ericsson Live. The technician say, they do not know what makes USB Portable hotspot Teathering and do not share the internet connection, so they replaced my phone.
Hi, a couple of stupid questions .... does your phone have mobile data connection? If yes, did you enable it?
Go through the User Guide, page 71, Sharing your Phone's mobile data connection.
http://www-support-downloads.sonymobile.com/wt19/userguide_EN_WT19_1253-7938.1.pdf
- Thread moved to correct community -
Yes I have mobile data connection, but if i use poertabel hotspot, the mobile data connection isn't work on my laptop...
Ok, same result if you connect to another laptop?
Yes... Same on another laptop & others...
Did you follow the instructions as stated in the User Guide?
Maybe you could tell us how you go about with the process, we might be able to figure out something ....
Great! Glad that you have sorted out the problem.
